Accessing bulb in side mirrors
Can someone please advise as to the process for removing the bulbs in the side mirrors on the IS250? Also, what bulb type is it?
i believe they are 194 bulbs, search the threads i seen the postings.two ways you can go about it. tilt mirrow all the way up and then pull on the mirrow and it will pop off the hinges, the other way is tilt the mirror all the way in towards the car and remove the screw which lets you access the housing. Im changing mine this weekend to white.
here is the two threads
https://www.clublexus.com/forums/sho...=mirror+lights
https://www.clublexus.com/forums/sho...6&postcount=43
jasprit
07-12-11 11:52 AM
