instructions for DIY HID Fog lights?
i promise i used the search for like days and ive given up... all i can find is DIY FOGLIGHT BULB install. im looking for some instructions on how to wire up standard HID conversion kits... the kit i purchased has no instructions and it plugs right up fine but wont work, whats happneing? please, anyone with same experience let me know before i chew out the guy that sold me the kit for sellin me a defect
If your kit is anything like mines, if you look at the OEM plug you will see that its labeled + -, but the only thing is, is that its opposite. You have to put - to + and + to -. Make sense? Trust me I was like that too, and I figured hey worth a shot and voila! it worked!
Trust me I thought the same at first and I put it + to + and - to - but nothing and I was like WTF?!?! So I was like what the hell might as well try, its a brand new kit so I did it and it works perfectly I love my 3000ks!
BTW danger4o5 you dont happen to have a Black IS do you?
okay, ill try flipping it but i know that it wont plug in easily cause it a plug that has like a piece in the middle to prevent the mix up between neg and pos. hmmm, should i splice some wires to make it flip ? i guess ill have to see. but yes, anyone with some pics and instructions would still greatly help us all
The + and - are indeed reversed. At least they were on mine also.
You have to actually remove the wires from the kits plug, and swap them. All you need is a small screwdriver to pop the pins.
Pretty sure you need the male connector.
After some searching, I found a place with female sockets.
On Ebay, there's a kit that includes wires, that you could just pull out. Like 10 bucks.
http://cgi.ebay.com/ebaymotors/ws/eB...m=200107970730
okay. so i think i got it. somehow reverse the positive and the negatives and it should work? ill try it this thursday and get back to you guys. ill try without the connector on ebay but that connector does look like it will do the trick. thanks guys... ill end up being the first to write up the how to DIY fog hid install
