Premium Audio Sub Lo pass rolloff
The Premium Audio System is pretty decent in terms of Mids\Highs. Does anybody know the stock amp Lo pass roll off freq. that feeds the sub?
I hope that a simple LLC can be installed without a need of a crossover to a aftermarkt amp and sub of choice.
I had to run a JL Cleansweep on my sub.... the cut off was too high and the 10" Fosgate P3 sounded like a clapped out Pep Boys 3-way speaker.
A cheaper way to go is the Audiocontrol line summing units.
I believe the cutoff is variable, dependent on the volume setting. It is designed to have a higher cutoff value to protect the speakers at loud volume levels.
Thanks unit74 and IS250jet..
I did find some post from CMusic regarding the rolloff. I may just pickup the Audio Control LC6i instead of the $35 LLC.
swartzm
05-07-02 01:15 AM
