Quick OEM Front lip question
I did search but I didn't find the result. The answer is probably out there but I couldn't find it. Searched for front lip, DIY, mount, etc.. Anyhow, the OEM front lip --- Does it mount on with double sided tape and screws? I have a clear bra on the entire front bumper from AeroTect, I am concerned about mounting the front lip if the clear bra is already on. Not sure if double-sided tape with bond well to the front lip.
Thanks guys.
Thanks guys.
Thanks guys.
Thanks guys.
https://www.clublexus.com/forums/sho...poiler+install
I also have the clear bra form AeroTect, don't worry!! the 3m tape will hold fine on the clear bra. Also it has clip and a screw on each side, but I didn't use those because you will need to make two holes on the bumper for the screws to go in, The front lip will hold fine with 3m tape only, and also it uses 7 screws on the bottom of the spoiler but you dont need to drill holes for those.
Here is DIY.....
http://www.infoarena.com/lexus/airdaminstall/
Here is DIY.....
G35TOIS350
12-18-06 11:10 AM
