Questions for those who did nav hack
well, i subscribed to the tech info toyota site and studied all the wiring for the non nav and nav, i wil tell you this, if you are NOT comfortable taking apart your dash, then dont attempt this. you also have to take out the glove box to look behind it to get to the CAN computer and speed sensor and tap into those wires. and if you want to do the back up cam, u need to also tap the reverse wire on the drivers side.
the over head console is just held on by 2 screwed and you have to pull down as its held in by clips. then run the wire from behind the nav unit up the pillar to the overhead.
When you remove the nav unit the whole CD changer comes out along with the Nav screen and clock bezel right? My question is can you separate the CD changer from clock bezel? I'm asking because I bought the whole nav unit from Lexusaudio without the ML DVD changer so I assumed that I'll be getting only the Nav screen plus the clock bezel below. But I've seen pictures here people taking out the unit with the whole thing attached and not separable.
Thanks Pnice. I'll let the shop do this.
The nav unit cost me about $2500 that includes nav screen, steering wheel controls, backup camera, mic, and all plugs and adapter. With the installation I'm looking about $3000 total. More expensive than buying with factory build but I'm out of options aside from aftermarket.
you guys have his contact info by any chance? if so can you PM the info. for those who did the swap does all the functions (ie, bluetooth, nav, climate control...etc) work without a hitch?
