wanting to make the ride more comfortable/smooth
10-05-07, 01:14 AM
I want to make my car smoother than it already is. I know I can do that by getting better tires but, is there anything else I can do to make it a smoother ride?
Also, any suggestions on tires?
10-05-07, 01:29 AM
u could go 17" rims and any touring tire should help, short of getting into boat mode..
10-05-07, 01:38 AM
I want to be able to avoid boat mode, if possible. I also want to keep the stock 18s...anyone rec. good luxury sport tires?
10-05-07, 06:51 AM
Quote:
Originally Posted by
ByoungWoo
I'm sorry but Luxury and Sport don't go together. I don't think you will find a luxury sport tire.
Maybe you got the wrong car? Maybe you should have gotten the ES350 instead.
10-05-07, 06:55 AM
ByoungWoo
I'm with ya' there. I wished mine (wives) was a little softer too.
Sometimes I feel like I'm in a 3rd Gen Mazda RX-7.
Cheers,
Old Oiler
10-05-07, 06:56 AM
I run 32 lbs air all around which helps.
10-05-07, 07:15 AM
Joeb427
Does it cause your tires to wear anymore on the edges?
I still love that roach, man! I laugh every time I see that on the screen running around!
Cheers,
Old Oiler
10-05-07, 07:23 AM
Old Oiler
Cheers,
Old Oiler
I don't know.
I only do about 7K a year on the IS so I'm not going to worry about it.
Can't step on that roach,either.
10-05-07, 07:49 AM
ByoungWoo
you arent going to gain much without changing to a thicker sidewall tire/wheel combo. The car feels smoother at 35 psi than at 32 psi than someone suggested
10-05-07, 07:51 AM
4TehNguyen
How is that possible over seams,small bumps etc?
10-05-07, 08:02 AM
Joeb427
and you probably get the TPMS low tire warning light as well.
10-05-07, 08:05 AM
gsrthomas
No problem with the TPMS.
Did come on one time I had a slow leak at around 28lbs or so..
"The systems under the new rule are to alert motorists if any tire falls 25 percent below the recommended inflation pressure"
10-05-07, 11:42 PM
Hrmmm...any suggestions on good softer compound tires that will make the ride smoother and grip better?
10-06-07, 04:29 AM
ByoungWoo
Living in Southern Cal,I'd go with an Extreme Performance Summer,Max Performance Summer or Ultra High Performance Summer tire.
Check with
www.tirerack.com .
Boris4ka
Wheels, Tires & Brakes Forum
07-17-10 10:26 PM
slee18
01-19-10 01:46 PM
AlBoston
12-26-07 12:10 PM
kaetamer
16
09-17-05 07:49 PM
