Took off the bottem panel near the pedals to change them and now they are lose
i have them cliped in tightly and screwed in but they still move in the back is that normal...just so im clear its the panel between the knee air bag and the pedals....
1. make sure you slide the panel into a little clip before you screw the panel in. look under the dash area to the left of the steering wheel shaft and you will see a metal clip that holds part of the plastic panel in.
2. on the top edge of the black panel, there are 3-4 plastic tabs that need to be pushed into the upper trim, you will hear it click into place.;
3. dont forget to screw in the 2 screws!
