Need definitive answer, will the 18s from the rear fit up front ??
Does anyone know for certain if 18 x 8.5s with offset of 50 (meaning rear rims) fit the front of an IS without problems ???? I ask in considering 18 x8.5s all around fitted with 245 40 18s.... has anyone done a rotation to see if the fit works ????
Sizewise they will fit, however, since the rear wheels have a different offset, they might not clear the brakes. I'm not 100% sure of this, but I think that's what will happen.
They will not fit. When I was researching offsets for my wheels, I took off the front and put the rear (with the 255/40/18) wheel up there. The tire was rubbing on the spindle.
You would have to go with a very skinny tire (probably 215's or skinnier) to have a chance.
I have 235/40's on an 8.5" wheel that has a +40 and I can barely squeeze my pointer finger between the tire and the spindle.
Macgyver
Wheels, Tires & Brakes Forum
04-20-06 10:20 PM
