anyone figure out how to get this (headlamp) cutoff yet?
okay guys, my car is almost a year old... 1 yr in december which also means my membership here is about 1 year; 1 year ago i already started trying to find out how to make my headlights do this...
http://i89.photobucket.com/albums/k2...284/Color2.jpg
anyone?
anyone?
I'm working on that right now, right now I swapped out the lens for s2000 clear lens and it only gave color to the side of the cut off. I just ordered E30 clear lenses and when it gets here I'll try to swap it over and see if it will work.
that's when u put a washer between the lens and the reflector bowl. By doing that you might get a bluer cutoff.
Oh btw, this is the TRUE way of getting that blue/purple look from the headlight, not the easy way of changing out the bulbs.
I tried spacing the lenses but the output came out all weird. I'll open up the headlights again when I get the other clear lenses and I'll try to mess around with it some more. I might just retrofit the s2k projectors into the headlights instead later, I just gotta get my hands on a pair. Plus with the design of our headlights its going to be hard since the bulbs go in from the side of our projectors. I know that I can make the s2k projectors fit in the headlight its just the matter of do I have room to fit the bulb, plug and my hands in at the same time.
