08 IS250 Bulb Size
08 IS250 Bulb Size
Hi Im new to the forums and proud owner of an 08 IS 250. My car didnt come with the factory HID's so I wanted to upgrade. Can someone please tell me what size bulbs my car uses? - Thanks
Lexus charges 875dls for the HID package:
Bi-xenon High-Intensity Discharge (HID) Headlamps
An inner shade retracts within the headlamp, allowing the High-Intensity Discharge (HID) light to work as both a low and high beam. This results in a brighter high beam. The Bi-xenon feature now enables high beams to rotate as part of the Advanced Front Lighting System (AFS) in order to better illuminate curves.
but thats a factory only option.
Also, can anyone please tell me if its hard to change out the bulbs? I opened up my hood and noticed that there are all these panels that cover up most of the engine bay. My older car was easy because it was easily accessable.
then just find the moisture caps and flip the bars over the retaining barrier. twist and pull the wire and bulb out, and unscrew your bulb.
replace and reverse the above.
