Outside Temperature & Tire Pressure Monitor
Does anyone know if a big change in outside temperature can affect the tire pressure monitoring system?
We had a cold front come through South Texas today and the temp is normally around 95-100 but its currently <70 degrees. When I got in my car after work I am getting the "low tire" warning. I visually checked each tire and couldn't see anything that looked low so I drove to the nearest Auto Zone...bought a good digital tire pressure gauge and tested each tire...all are at 27.5-28 psi.
Not sure what is setting off the alert...only thing I could think of was the weather.
the recommended PSI are as follows:
Front: 35 PSI
Rear: 37 PSI
I happened to me once (low tire warning), I checked the pressure and it was around 30PSI on all 4 tires.
Front: 35 PSI
Rear: 37 PSI
This happened to me this morning, went to go to work this morning (kinda chilly out) and got low pressure message. The tires didn't look low but one of the rears was around 30psi.
They should have done a real time pressure info on each tire.....
Received 1,063 Likes
You should check your tire pressure once a month... ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Also, don't check them after a long drive or on a super hot time of day...
Try to check them via the shortest drive to to the gas station in the morning..
Joe Z
Joe Z
