Reset after battery disconnect
Does anybody have a good idea what rests if you disconnect the battery in an ISx50?
I know there is the power window issue..which is easily taken care of, the ECU resets.which basically fixes itself as the car relearns, the clock will reset..no bid deal..
What about things that the user can set..like seatbelt buzzer, door lock options? These can always be re-done if need be..but would rather not have to deal with it..
Most importatly..what about the Personalized Settings the dealer has to do?
These would be a bigger hassle since it will cost $$ to do.
Thanks in advance
Thanks in advance
when i disconnected it(negative first) the clock,memory seats,seatbelt buzzer were reset to the factory settings.
however the Nav marks i put are still there,and the door lock opening is the same( i made it open all doors when i open the driver's door)
i dunno about the LPS cuz i didn't change anything.
and drive the car pretty hard while it's still learning,if you are a "always floor it" type of driver's.
kchow510
01-09-24 10:44 PM
