Momo shift knob
Momo shift ****
Has anyone bought thishttp://www.ltbmotorsports.com/mocoevoch.html
Momo shiftknob and will it fit 2IS? It's the simplest mod but hardly anyone mentioned it.
^^^ I believe someone on here has a similar shift ****. If it's not the same style, it's the same brand, MOMO. It fits with no problem from what I heard. Try to search for it.
That was my post: https://www.clublexus.com/forums/sho...highlight=momo
Almost all MOMO's are a direct replacement for the stock ****. Just unscrew the Lexus ****, then use the largest rubber spacer (included in the MOMO kit), and secure the **** with the three set screws. It takes about 10 minutes. The MOMO **** you are looking at is the same as the one I used except your's has a polished aluminum insert and mine has a perforated insert. Other than that they are the same. It is a bit bigger and more substantial than the stock ****.....it gives you something bigger to grab on to. The leather and stiching is first rate in typical Italian style, and has a nice tactile feel to it that is missing from the Lexus ****. Very happy with mine. Makes a nice change to the interior for <$100.
Almost all MOMO's are a direct replacement for the stock ****. Just unscrew the Lexus ****, then use the largest rubber spacer (included in the MOMO kit), and secure the **** with the three set screws. It takes about 10 minutes. The MOMO **** you are looking at is the same as the one I used except your's has a polished aluminum insert and mine has a perforated insert. Other than that they are the same. It is a bit bigger and more substantial than the stock ****.....it gives you something bigger to grab on to. The leather and stiching is first rate, and has a nice tactile feel to it that is missing from the Lexus ****. Very happy with mine. Makes a nice change to the interior for <$100.
Yes, the Combat Evo Airmetal (perforated mesh) is about $15 more than the ones with chrome, silver, blue, or red inserts. It's also available with a carbon fiber insert.
