change to synthetic now or not?
As far as break-in, it’s done however; there are high levels of debris circulating in the system that will need several changes to fully remove. So, I suggest you get your freebees (oil change, search TSIB). This will give you an extra change before switching to synthetic. If you want to extend your OIC (oil change interval) I suggest you use premium group IV synthetic such as (my personal favorites) Amsoil 0w-20 or the re-formulated 0w-30. The reasons why I chose these oils, they have proven to hold a safe TBN number for a minimum of 10K miles in many Toyota/Lexus engines. You can analyze the oil to determine how long you can safely run that oil. A member here ran the factory fill 10K miles (*****) and it was still safe. This indicates that the 3.5 is gentle on oil and you should be able to safely extend the OCI. Considering that the IS engines have VVTi which uses the motor oil as the media to actuate the variable cams, I feel a low temp high flow oil is also a big plus.
If you intend to run the OEM recommended 5K mile OCI you can use just about anything within the recommended viscosities.
Koz
Koz
Tech Info Resource
TBN number? You working for the department of redundancy department or what? Do you actually know what TBN stands for and means? Or why it's important?
There's an incredible amount of misinformation and religion surrounding oil. Most of what you hear is absolutely BS.
If you've fully broken in your engine (run at full load for at least 30 seconds) then you can change to any oil you like and you'll be fine. And you don't need German oil to adequately protect your engine at US speeds. It's again a bunch of crap foisted on an unsuspecting public.
0w-20? hummm. is that really a good one for our is's, im going to take my car in for a oil change in about a week n i was about to go pick up some amsoil 5w-20 cause it seemed as if thats what every one uses. any info u could give on the differences between the 2? and would u recommend the 0w or the 5w(oil idiot here)
The reason I am not going to the dealer is because the dealer near me is incompetent. And, I can change the oil faster than I wait for them to change it for me, without the worry of curbing the wheels etc. I don't care about the oil and filter material cost. Took them all day to do the brake TSIB and they simply put in the exact same pads and not the updated ones. So I am just going to put in pads of my choice when the time comes.
Koz
Koz
Funny, I was thinking of this thread today while doing my 5th oil change. I did all the usual steps, backed the car off the rams, let it run for a minute, then shut it off and popped the hood to check the oil evel.
A huge pool of new syn. oil had come out from my car. I freaked out, started the car, pulled back up on the ramps, then shut it off. Looking underneath I discovered oil pouring from the filter area.
*****VERY IMPORTANT*****
What I did wrong was to slide the new rubber o ring to far down, thus creating a rubber ring bumper that was visible after tightening the housing cover. I slid off the o ring, it was stretched out so I grabbed another new one and put it on properly. It should go almost all the way so that it ends up just lower than the metal ring with the 1/2" breaks in it. A stupid mistake that cost me hours cleaning up (and $27 in syn. oil).
Tech Info Resource
If this post is directed at me please say so. If it is, I don't understand or appreciate your condescending tone. Apparently you feel that I posted misinformation. If so, please enlighten us. I know fully well what the TBN is and how useful it is if you plan on extending your OCI (that’s why I mentioned it). If you feel this is BS, then again, enlighten us. I read your posts (which most are very good) and wonder why/how you can make these statements. Do you believe that you simply run an engine at full load, for 30 seconds, and it is broken-in? Do you believe that high-way speeds dictate the need for premium oil?
Koz
Koz
It is only one factor when determining OCI. All TBN tells you is how much base is left in the oil to neutralize acids formed as byproducts of combustion. It really is NOT the determining factor for how long the oil can be safely run.
Viscosity breakdown, total element content - particularly iron, and fuel/coolant contamination rates highly trump TBN for determining OCI. Ask Blackstone. I had a long conversation with them about my results on more than one occasion.
LexPegged
ES - 5th Gen (2007-2012)
18
04-24-16 12:21 PM
