Need help: Check VSC
Old 10-30-07, 02:25 PM
Hartawan
Former Vendor
Hartawan's Avatar
Default Need help: Check VSC
So I haven't driven the car for the past 2 days and just now I turned it up to check and see if my pipe bomb held the air good inside (which it didnt).
As I started the car, that horrible engine cranking noise was there and a second later I smell something burnt. A second or 2 later, CHECK VSC was on as well as my traction control light on the bottom right.
Any ideas?
Old 10-30-07, 03:08 PM
ggzoa
ggzoa's Avatar
This happened to me about a year ago and the problem was a bad gas cap. Make sure it clicks when you close it. It took the dealer 3 tries to diagnose the problem. Hopefully this is your problem and not something worse.
Old 10-30-07, 05:15 PM
Hartawan
Former Vendor
Hartawan's Avatar
interesting, i will try that as soon as i get back. thanks.
Old 10-30-07, 05:52 PM
Hartawan
Former Vendor
Hartawan's Avatar
I just checked my gas cap and CHECK VSC is still on.
Old 10-30-07, 06:30 PM
Hartawan
Former Vendor
Hartawan's Avatar
Sam (exclusiv) linked me to here
https://www.clublexus.com/forums/sho...U+running+rich
Old 10-30-07, 06:40 PM
ecr527
ecr527's Avatar
I had the same problem happen to me a few months back. I brought her to the dealership and they told me that it was a broken gas cap. They ended up replacing the cap and the problem went away.
Old 10-30-07, 06:58 PM
Hartawan
Former Vendor
Hartawan's Avatar
Okay cool, bringing it to the dealership on monday. Hopefully it is just a broken gas cap.
Old 10-30-07, 07:25 PM
ecr527
ecr527's Avatar
You should do a search on this topic. There are numerous threads on this and this isn't the only reason, that's been causing this problem.
Either way, good luck with it.
Old 10-31-07, 09:16 PM
NotoriousB
NotoriousB's Avatar
Hey I had this same problem, I thought it was the gas cap but it wasn't. Took my car into the dealership and my service advisor told me it was a problem with the O2 sensor. The computer thought there was too much air entering so the computer inturn would burn slightly more fuel to compensate, since the engine dynamics change the vsc automaticly shuts down since it monitors engine rev's (apparently its a saftey precaution the computer takes so the vsc does not react in an adverse manner). So what happned was I got an upgrade in the software and its been fine since. Apparently its a know issue on 06, and 07 IS's.
Let me know what happens
Old 10-31-07, 09:23 PM
cspec
cspec's Avatar
Damn Tommy... going back to the dealership again...
Old 10-31-07, 09:33 PM
t0e
t0e's Avatar
take ur rims off this time
Old 11-01-07, 06:50 AM
Hartawan
Former Vendor
Hartawan's Avatar
Heh, this time im going to spend 10 minutes checking my car.
Old 11-01-07, 08:20 AM
siren05
siren05's Avatar
I had same thing happen too me on my 250,brought it too the dealer turns out random misfire on cylinder 1,also turns out there is a tsb for all 06 250's,something to do with bad lifters on cold start car is in dealership right now getting surgery on valve train
Old 11-01-07, 08:55 AM
Bichon
Super Moderator
Bichon's Avatar
Check VSC turns on with the check engine light. In order to diagnose the problem, someone will need to connect a scan tool to the diagnostic connector (under dash near the driver's left knee) and read the DTC code; since the car is under warranty that might as well be the dealer.
Old 11-01-07, 05:45 PM
Hartawan
Former Vendor
Hartawan's Avatar
Heres another bit of info that I left out.
As soon as I started, the car was shaking. Never felt anything like this before.
Quick Reply: Need help: Check VSC
