Lexus announces 'F-Sport' line of accessories for 2IS
#32
Guest
Posts: n/a
I swear some of you can complain. I am happy for one. SUper conservative Lexus is listening and this is just the begining.
I am SHOCKED at the carbon cermamic upgrade. THis is only on exotics and Audi RS cars. WOW. Incredible. I think that is clearly for IS-F owners (though reviews of the stock brakes on that car have been great).
Go Lexus!!
Go Lexus!!
#36
Bigger pics!
First the confirmation...The bodykit & trunk spoiler are a re-badge of the oem versions. Also, the axle-back exhaust is a re-badge HKS (dealership version). Anyone that has taken out their oem airbox, can you guys confirm the pic in the link is an oem airbox? If yes, then that's just a JoeZ intake tube, lol.
http://carscoop.blogspot.com/2007/10...s-f-sport.html
#38
What the wheel offsets are? Figure that out pickup something you like better in the same size..use the recommended tire sizes..and you should be good to go.
Who is making the springs..they gotta be contracting this out to somebody..maybe Eibach?
The non-ceramic brakes look interesting..wondering if they come in different colors.. Gotta be pretty spendy..I remember seeing somthing about Brembo's running about $6K
C
#39
Guest
Posts: n/a
http://pressroom.toyota.com/Releases...T2007103003431
Lexus Debuts F-Sport Performance Accessory Line At 2007 SEMA Show
10/30/2007 Las Vegas
October 30, 2007 – Las Vegas - Lexus today unveiled F-Sport, its first-ever performance accessory line available for the IS 250, and the IS 350. The line was premiered at the 2007 Special Equipment Marketing Association (SEMA) Show in Las Vegas, where the appearance marked the division's first official participation at the show, attended by more than 100,000 industry leaders from over 100 countries showcasing the latest in automotive products, electronics, and aftermarket accessories.
"The Lexus IS 250 and IS 350 sport sedans are specifically geared for the performance-minded customer," said Brian Bolain, Lexus national interactive and automotive events manager. "The F-Sport performance accessory line helps to further realize each owner's desire to personalize their car's performance to best match their needs."
The F-Sport Accessory Line includes a wide cross-section of performance enhancing products engineered by TRD and covered by the Lexus new vehicle warranty, including:
F-Sport 19" Forged Alloy Wheels
This lightweight forged alloy wheel, exclusively designed in a dark graphite finish, includes a staggered fitment with 19" X 8" front wheels and 19" X 9" rear wheels. Recommended tire sizes are 225/35R19 in the front and 255/35R19 in the rear.
F-Sport Front Brake Upgrade
The Front Brake Upgrade provides a firmer pedal feel and improved fade resistance in repeated severe duty use. The Brake features six piston fixed calipers, and drilled cast iron 355mm diameter rotors with a patented internal fin design mounted on anodized aluminum hubs. Braided stainless steel brake lines and low-dust performance brake pads are included and the upgrade can be used with stock or F-Sport upgraded rear brakes.
F-Sport Rear Brake Upgrade
Similar in construction to the F-Sport Front Brake Upgrade, the rear brake upgrade uses four piston fixed calipers and drilled cast iron 345mm diameter rotors. Braided stainless steel brake lines and low-dust performance brake pads are also included. The Rear Brake Upgrade may only be used in conjunction with F-Sport Front Brake Upgrade.
F-Sport Continuous Carbon CeramicTM Brake Upgrade
A new generation of carbon fiber-reinforced ceramic material technology maximizes high-temperature durability and system cooling in this ultimate upgrade for the IS F. Ceramic rotors measure 380mm diameter front and 355mm diameter rear on anodized aluminum hats. They incorporate the same internal cooling vane concepts as the F-Sport cast iron rotors, while significantly reducing unsprung and rotating mass compared to the IS F stock brake system. Distinctively finished six-piston front and four-piston rear fixed calipers signify leading-edge technology and performance. Specially qualified performance brake pads and stainless steel brake lines are included.
F-Sport Exhaust System
This system features all stainless steel construction with fully polished mufflers and double-wall exhaust tips. In addition to an outstanding appearance, it delivers a powerful, sport-tuned exhaust sound.
F-Sport Lowering Spring Set
This feature lowers the vehicle approximately 1" in the front and rear for a more aggressive appearance and a lower center of gravity. The spring set is engineered to deliver lowered ride height without bottoming out or creating a harsh ride. The feature can be used with either the stock or F-Sport shock absorber set.
F-Sport Sway Bar Set
This includes a set of larger diameter, replacement front and rear sway bars that offer reduced body roll and flatter cornering. Urethane mounting brushings are also included to replace the original rubber brushings.
F-Sport Bilstein Shock Absorber Set
Developed in cooperation with Bilstein and available exclusively through the F-Sport Performance Accessory program, this shock absorber set offers sport-tuned suspension dampening without sacrificing ride quality.
F-Sport Clutch
The F-Sport Clutch increases clamping force approximately 15% to handle higher torque capacity and provide improved feel.
F-Sport Quick Shifter
Engineered and machined from billet aluminum, the F-Sport Quick Shifter decreases shift throw by approximately 30% for positive shifting.
F-Sport Rear Chassis Member Brace
To improve chassis stiffness under aggressive driving conditions and provide a more responsive feel during cornering, the F-Sport Rear Chassis Member Brace joins key rear chassis and suspension mounting points through this tubular steel brace.
F-Sport Carbon Fiber Engine Cover
Constructed from real carbon fibers, this very light and durable engine cover provides a high-tech appearance under the hood. This is a direct replacement for the original cover and is only available for the IS 350.
F-Sport Air Intake
This low restriction intake and filter assembly is fully compatible with stock engine controls and is emission legal in all 50 states.
Lexus Genuine Accessory Ground Effects Kit
For a lower, more aggressive appearance, this color-keyed four-piece body kit includes front and rear valences and side skirts.
Lexus Genuine Accessory Rear Spoiler
This rear deck mounted, color-keyed lip-style spoiler provides the finishing touch for the sport-tuned enthusiast.
The F-Sport performance accessory line will be available in early March 2008, and will be sold through Lexus dealerships. Details will be available in 2008 through the Lexus.com website within the IS 250 and IS 350 sections. For additional information regarding the F-Sport performance accessory line, please contact Lexus Division Communications.
About Lexus
Lexus has become synonymous with luxury since its introduction in 1989. By offering some of the finest quality luxury vehicles and providing benchmark customer service, Lexus has remained the top-selling luxury nameplate in the United States for seven years in a row. Lexus and its 223 dealers have repeatedly achieved high honors for both the products they sell and the customer service they provide.
F-Sport Clutch
F-Sport Air Intake
About Lexus
#45
F-Sport Clutch
