Removing Backseat
soem guy did remove the back seat when working with his audio setup. he gave a good instruction on how to remove it too..try searching "audio" but imma try to find it myself too..been awhile. and i'll post the link.
the seat itself (seat cushion) is just held down by two tension clip. There are two clips. just grab the seat in the middle (by middle i mean, if you were sitting on the seat, the middle would be the area between your legs) - and pull straight up, it'll come right off. Do the same for the other side.
once you get the cushions off.....i believe there are big screws or bolts that you take off to get the back cushions off....what are you trying to do?? you know theres nothing behind the seats but a big metal plate??
If I ever make it to more trackdays/autox/etc., I'll probably take out lots of stuff that only requires hand tools ...
I'm planning to put a sound insulation material back there.
