Tire pressure Monitors
Do the monitors tell you the pressure in each tire or only when they are low? I had an alert saying low pressure, but it didn't tell me which tire or the pressure. I didn't know if this was like the monitors in the vettes.
Thanks
Thanks
Wow, I was expecting a little more from Lexus. Might as well just put an old man in the trunk to kick the tires before I start it and give me a thumbs up or thumbs down.
Thanks guys for your info.
Received 1,064 Likes
You really shouldn't rely on the TPMS to tell you when air is needed regularly.
Its good for slow leaks, nails, etc, etc...
Everyone that owns a car should either check their own or find a shop that will check them for you..
ONCE A MONTH DIY is HIGHLY Recommended!!
My thoughts, exactly. Lexus makes you check all 4 which is what you SHOULD do in the first place. Genius, really.
Or how about this....when the electronics cycle on startup, the display quickly shows you the pressure of each tire?
Well, if we could get real time numbers @ all corners that would be much more useful......even if we could only check them when the car is stopped, the parking brake is on, the wipers are off, (fill in other annoying nanny feature here).....
my dad gets freaked out by how low pro my tires are, i catch him checking my tire pressure all the time and checking my lug nuts to make sure there tight. a little weird but i guess he's worried.
Well I gotta say the 1st time I needed this system to work and it did its job perfectly.. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Friday morning 5:30am , just getting ready to leave for work and when I started the car > I got the low tire pressure warnings..
At first I was like man, I just checked all the pressures last week, what could be the problem??
I do a quick visual check of all 4 tires and again nothing..![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
So I take out my trusty gauge and start checking each tire.. 35, 38, 35 and then of course the last one i check on the rear passenger side was 25..
After some more insepecting I found a nice screw right in the tread..![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
I ended up just heading to the gas station and topping the tire off with air, since I can tell the screw wasn't going anywhere and the air leak was slow.
FU to who ever drops screws on streets....![Slap](https://www.clublexus.com/forums/images/smilies/slap.gif)
