For all owners of AFTERMARKET HID !!!
Old 11-16-07, 08:51 AM
J250
J250's Avatar
Default For all owners of AFTERMARKET HID !!!
Hey,
I just have a question for all owners with aftermarket HIDs. I had my Mtech 6000k professionally installed for my IS250 couple months ago. These couple weeks when i drive around for around 20 minutes.. I start to smell this weird burning smell. It smells like using a laptop or electronic for long time and produces that heat smell..
Just wondering if it is the HID's problem or something else?
Thanks!!
Old 11-16-07, 09:17 AM
iameric
iameric's Avatar
That used to happen on my accord after I first installed my HIDs I forgot what it was though, wish I could help, the only thing i remember was that it eventually went away.
Old 11-16-07, 03:23 PM
Alex350
Alex350's Avatar
I have installed several HID aftermarket kits on my cars and have never smelled anything like that. I suggest you take it back where you had it installed and tell them to check the system and see if there's anything wrong with the installation or with the system.
Old 11-16-07, 04:06 PM
Tchan1
Tchan1's Avatar
Did you have a wire harness when you bought the kit? If not it could be your OEM wire harness melting. Whenever you install a kit you must have a wire harness because our OEM ones won't be able to handle the extra jolt of watts the ballast draws when starting up.
Old 11-16-07, 04:21 PM
RFFG
RFFG's Avatar
Shouldn't be smelling if it's installed correctly I believe...get it checked out...
Old 11-16-07, 04:47 PM
josephdoc
josephdoc's Avatar
I don't think there are burned wires because Mtech is pretty much clean-install especially it was done by pros. Check your lens housing. Just pray no burned marks inside your lamp housing. Try to ask the installer just to go over the circuit again.
How much is professional HID installation in these days?
Old 11-16-07, 09:37 PM
dappy
dappy's Avatar
I have a set of Xenon Depot HID foglight kits professionally installed and there's no burning smell. The smell could be a sign that something is melting. I would suggest you bring your car back to the installer to check it out.
Old 11-16-07, 09:57 PM
8 or 350?
8 or 350?'s Avatar
Sounds (or smells) like you might have some wires or some part of the kit either touching the engine or as some one else said it may be the light housing. I have had my mTech on for over a month now and no smell at all. I did the install myself. Have it checked out. Good Luck.
Old 11-16-07, 10:46 PM
Tchan1
Tchan1's Avatar
It doesn't matter if its professionally installed if the kit didn't come with another harness then your OEM harness will eventually be gone. Trust me, it almost happened to me because I didn't have a harness for my foglights. Luckily my fuse stopped it and I only had to change out my fuse and I put the harness along with it. I also lost one ballast due to that.
Old 11-17-07, 12:40 AM
Alex350
Alex350's Avatar
In my case, it would have been free, but no one would be able to tell it was done by an amateur
Old 11-29-07, 09:32 PM
J250
J250's Avatar
Thanks for the replies!
So i brought the car back to the HID installer and the smell wasn't coming from that .. The wiring harness and ballast is perfectly fine. No signs of burnt or anything unusual at all...
So any more ideas on where the smell might come from?
Thanks!
Old 11-29-07, 10:12 PM
Lextasy89
Lextasy89's Avatar
actually.. everyonce in awhile when i get out of my car it smells like somethings burning.. hmm
Old 11-30-07, 03:08 AM
Joeb427
Joeb427's Avatar
I'd run a battery line and relay to the battery to the HID's if you don't have one to play it safe.
MTEC says you don't need one but from what I read on a few sites you should add one.It's a matter of time before you may have an issue with startups on your OEM headlight harness.Some have said after 100,200 starts but eventually...I don't know how true that is but I wouldn't take a chance.
Many kits like Xenondepot's Xtreme I just bought have a battery line and relay included in their kit.Those HID's draw a lot of power when firing up but only 35 Watts after.
Old 11-30-07, 08:38 AM
mikeho
mikeho's Avatar
MTEC installation's really simple, so I don't think it would be that. There's always debates about whether you need a relay harness or not. Of course, it's always easy to play it safe and have one... Has anyone who doesn't have a relay harness have any problems? I think I'm gonna ask that question to the lighting forum.
Chances are, you might have some oil sitting on the outside of the engine. If someone spilled some onto the engine, you're gonna get that burning smell.
Old 11-30-07, 09:52 AM
KA8
KA8's Avatar
No harness for both of my vehicles with aftermarket HID's. No problems so far.
Quick Reply: For all owners of AFTERMARKET HID !!!
