Squeaky spring inside driver's seat! :(
Old 11-19-07, 03:31 PM
ES3
ES3's Avatar
Originally Posted by Axvel
there is a TSIB for it look for it, they fixed mine
Thx, I've already had the TSIB done on the seat rattle from the track, beneath the seat, this squeak is definitely inside, and I don't believe has a TSIB. I'm sure we'll get it figured out. Just wanted others to know that it's out there, in case you notice any strange noises!
Old 12-04-07, 10:55 AM
ES3
ES3's Avatar
Update. They are ordering me a new seat, after noticing the seat/track appears bent.
Old 12-04-07, 01:04 PM
threefiveo
threefiveo's Avatar
Glad to hear Lexus is taking care of it..
I had a similar noise in my car, on the left side of the driver seat, it would squeek going around corners.. It actually turned out to be the rear seat bolts. Tightened those up, no more squeek.
Old 12-04-07, 02:30 PM
ES3
ES3's Avatar
Good to know, so you tightened it down yourself?
Regarding the new seat, I'm debating about just dealing with the current seat until just before my warranty is up... so I am gauranteed a new seat after 4 years of use with this one!
Old 12-04-07, 08:01 PM
threefiveo
threefiveo's Avatar
Yep, just move your seat all the way forward, pop the cover and tighten the bolts down, piece of cake. 14mm socket works perfect..
The bolts weren't loose to the point where the seat moved around, but were loose enough that the chassis flex around corners, and off camber driveways and such would cause a squeek.
Im not sure if it was the seat squeeking from the flex or the seat mounts moving around but it fixed it.. It was starting to drive me crazy, couldn't track down exactly where it was coming from.
Give it a shot, beats having someone messing around with the interior of your car.
Old 12-04-07, 08:21 PM
ES3
ES3's Avatar
I will give that a try next time, but the primary squeak this time around was coming from the inside of the seat.
Regarding the other items, I believe there is a TSIB for squeks from some bad clips, not related to the bolts you tightened down, keep that in mind if a different set of squeaks returns.
Old 12-17-07, 09:53 AM
ES3
ES3's Avatar
Originally Posted by ihkskim
17k miles more or less.
when i came the first time.. they put felt in it.. and it came back the next day.. went back again the following week and they gave me a new driver seat under warranty. Had to wait a month for it to arrive from jpn
Just got my seat, noticed a small crease at the corner, apparently it was condensed a bit from packaging and shipping. They say it'll go away over time. Did you notice anything like that on yours?
Buggeroff6
11-25-15 02:42 PM
davrober
RX - 3rd Gen (2010-2015)
09-17-12 09:35 AM
DenverSC
LX - 3rd Gen (2008-2021)
09-06-12 11:03 AM
IsdiorFlow
12-11-10 03:37 PM
concord
10-03-03 12:51 PM
Quick Reply: Squeaky spring inside driver's seat! :(
