DIY Request - Front Lip
This is probably the third DIY request i have posted and i am sorry to bother all of you. I have ran a search and cant find what i am looking for. Does anyone know of a DIY that explains how to remove the lip and install the new
OEM lip, or something in those realms...
Thanks.
Thanks.
I just did it two days ago, and it was quite easy. There are (I believe) 6 10mm screws and some clips holding the stock lip on. Peek under the lip, unscrew each of them, and give it a little tug. Should come right off. Install is the opposite.
Here is Techniques Front Lip DIY:
https://www.clublexus.com/forums/sho...=front+lip+diy
Here is my thread about the problems I had:
https://www.clublexus.com/forums/sho...ight=front+lip
I would HIGHLY recommend using a lift, jacks, or rhino ramps ($30 from Autozone). You need to be able to get your head under the car. It is much easier and you will avoid the screwup I had. Make sure you hear the clips snap into place!
If you need help, PM me.
JamesG
09-04-08 12:14 AM
