Aftermarket HID leveling for a flat cutoff?
Old 11-30-07, 12:42 PM
ba-b4
ba-b4's Avatar
Default Aftermarket HID leveling for a flat cutoff?
Okay I've installed an aftermarket HID kit (xenondepot) and want to level out the beams so that the cut off is even. Right now the right side is higher than the left side and I know that this was by design to not blind oncoming drivers on the other side of the road. My problem is it seems like the uneven part of the cut off seems to come from the drivers side headlight only as once I had a loose connection on the passenger side and with the drivers side beam still producing a uneven horizontal cutoff level. It's as if there's some piece in the headlamp assemble creating this and not due to the right head lamp at different levels than the left. Anyone who actually did the adjustments know how to fix this?
Here's a pic of how the cut off looks like right now. Even when I don't have the other headlamp on the cut off still looks like this! Thanks!
Old 11-30-07, 12:51 PM
DrShoe
DrShoe's Avatar
I have the XD HID kit too and my cut off looks like that. However, I have raised my projectors higher but the cutoff remains the same.
I think that's just how it is since we are putting HID in a halogen projector. I have never driven a OEM HID IS before so I do not know what its cutoff looks like.
Old 11-30-07, 12:57 PM
iialcii
iialcii's Avatar
The cut off is the same for both headlights. OEM HID, Cover your driver side headlight and you will see that the Passenger Beam is the same. At least on my car it is. I believe its OEM for HID to have the cut off on both sides. But I could be wrong. I have AFS
Old 11-30-07, 01:05 PM
ba-b4
ba-b4's Avatar
I know that these are halogen projectors but why is the driver side like that only? I don't think BOTH lamps are the same otherwise if they were the cutoff would be even but it's not. It almost seems like there's an extra piece in the drivers side lamp that is blocking out part of the beam. I'll try covering each of the lamps later tonight to see if both sides have the same beam pattern. I have a feeling they wont though.
Old 11-30-07, 02:23 PM
Joeb427
Joeb427's Avatar
The driver's side is lower for less blinding of oncoming traffic.
Old 11-30-07, 02:38 PM
ba-b4
ba-b4's Avatar
^ yes but even with JUST the SINGLE drivers side light on.. and the passenger side off the beam cut off level is not even. It looks like the picture up above in my first post.
Old 11-30-07, 02:46 PM
Joeb427
Joeb427's Avatar
Does the passenger side light blind oncoming vehicles?
My Xtreme kit is going in tomorrow.I guess I'll find out tomorrow.
That is if they come today like the I was told,Steve!
It's after 6 and no UPS delivery yet.
I've gotten UPS deliveries at 7 at times.Especially on a Friday.
Old 11-30-07, 03:10 PM
ek9vboi
ek9vboi's Avatar
The cut off is on both sides. When you pull up closely to your garage or w/e you can see both of them are like that. From far, they are a single beam pattern. Leave it as is... designed to be like that so people are not blinded.
Old 11-30-07, 05:46 PM
iialcii
iialcii's Avatar
It could just be the AFS lighting that has the cut off on both sides,mine are like that. try covering one headlight with a towel tonight while facing a wall. But Im certain both sides have cut offs for OEM HID at least
Old 11-30-07, 06:12 PM
Old Oiler
Old Oiler's Avatar
This is correct, I have factory HID and the headlights "stair step" up from left (drivers side) to right, but from a distance they appear "flat lined".
Cheers,
Old Oiler
OutGolfn
09-25-10 03:07 AM
ewu888
Lighting
28
03-04-09 05:56 PM
OutGolfn
04-07-08 10:50 AM
IS 350
11-11-05 04:17 PM
wcp
Lighting
10-18-02 11:48 PM
Quick Reply: Aftermarket HID leveling for a flat cutoff?
