Help with changing headlight!!!
Im sure its not hard for "anyone" of us but for me its about security, is it hard? What do i need? Most important what do i have to be carefull with?
I preciate if u guys have some picture for it, probably there is many threads like this, but im kind a newb and dont know how to search :P
Ho Motorsports
Are you talking about replacing your HID bulbs? If so, for the passenger side, you'll need to take off your air box which will require a 10mm socket wrench. For the driver side, you will need to take off the tube that connects to your windshield washer fluid reservoir (also a 10mm socket). Then, remove the low beam HID housing cover which is held down by a clip. That's pretty much what you will have to take off. The rest is just a matter of taking off your bulb and replacing it. I'll be changing out my bulbs tonight, so I'll take some pics.
Terrance
Terrance
