system install at bb but they wont' do it??
#31
The setup will fail if you bridge the channels before it going into the LLC. I'm not an installer by any means, i'm just another guy who loves DIY. Fortunately im not your average installer at CC or BB either. I input the signal wires into the LLC and I use a Y RCA to sum the channels up at the output. Now most amps on the market has a crossover that has a low pass ****. Only certain freq will be allow to enter the the amp so there won't be anything higher than 120hz can enter the sub.
I dont' want to explain everything all over again so please read this post that I made a while back.
https://www.clublexus.com/forums/sho...74&postcount=9
1. Did you sum the sub output and one channel? Or did you sum the left right and sub all at once??
2. If you adjust the zones on your stereo (driver, front, rear, all, etc) is the change in sub output audible?
3. Did you keep the factory sub connected?
#32
You did it right! I am very proud to say that you did a great job (except, i hope you mounted that amp ) More Questions:
1. The LLC has 4input and 4 outputs. The sub took one channel, the front L & R speaker take two channel and I used a Y RCA cable to sum the front speakers into one and the sub is on a channel by itself.
2. Oh yes it will change the sub output. The reason is because I adjust the LLC according to my taste. I lowered the level from the sub input and increased input level for the two front speakers. THose of you have hooked up the sub using the sub output know that you get a huge amount of bass. It's so much that it gives you a headache.
3. At first I actually took the stock sub out of the car but after a while I put it back in. It actually sounds better with the stock sub in, I think since we are using the stock HU, there are missing signals supposed to be going into the sub. Hence the aftermarket sub plays with some missing note. The stock sub isn't loud but it fills up all the notes that suppose to be heard from the music.
#35
#37
Raycow
01-19-16 09:04 AM
