Anyone running Fosgate 3Sixty1 or 2 ?
Can anyone tell me if the Rockford Fosgate 3Sixty series can expand the basic ISx50 stereo to a usable unit?, and if so, what is the setup you are using. Thanks.
Damn, I max the **** out of the system playing many killer tunes, the factory stereo sucks ***. Anyone who can help would be great. Thanks
I dont want to install a gay bhead unit
I've been talking to audio freaks and they say that the RF 3sixty should work.. i myself bought an audio control LC8, but its been sitting in my trunk for like 5 months.. too lazy and haven't had the time to get it installed.
The 3sixty is a fantastic unit. However, it only has 6 channels of input that can be summed to create a full bandwidth signal.
The question is do you have 6 channels (3 left/3 right) that you can tie into the 3sixty to create a full bandwidth signal through summing? It depends on the crossover setup of the IS.
If all speakers have dedicated amp sections with active crossovers, you may be screwed.
If there is a full range signal going to a passive crossover than split to each speaker, you should be okay. You can tie that full range signal going into the crossover into the 3sixty.
If you are split between a sub, front woofer, and front mid/tweet combo, you can tie those 6 channels into the 3 sixty and you're golden.
Kevin
08-18-01 09:21 PM
