Dealer says G-Spider alloy wheels don't fit on IS 250 AWD
Old 12-24-07, 04:49 PM
SAFNYC
SAFNYC's Avatar
Default Dealer says G-Spider alloy wheels don't fit on IS 250 AWD
I just got back from my local Lexus dealership. I am looking to get a 2008 IS 250 AWD with the 18" G-Spider Alloy wheels, but the dealer is telling me that those wheels are only for the IS 250 RWD and IS 350. I looked in the brochure and could not find any fine print that indicated a restriction on these wheels for the IS 250 AWD.
Does anyone here have an IS 250 AWD with 18" G-Spider Alloy wheels?
Thanks
SAF
Old 12-24-07, 04:55 PM
CAIFAN_64
CAIFAN_64's Avatar
lexus has two sets, one staggered and one non staggered. get the non staggered one, that one will fit.
http://www.lexus-parts.com/parts_det...id=88797&all=Y
Old 12-24-07, 09:11 PM
brodie
brodie's Avatar
The non staggerd set is for the GS350.
Old 12-24-07, 11:58 PM
Irishman06
Irishman06's Avatar
Yup, you need the GS set for the AWD IS.
Old 12-25-07, 01:05 AM
carchitect
carchitect's Avatar
They make 2 different G-spiders. An 18 X 8 -45 and an 18 X 8.5 -50. The GS uses the 18 X 8 -45 on all four. The IS uses the 18 X 8 -45 on the front and 18 X 8.5 -50 on the rears. The SC430 uses the 18 X 8.5 -50 on all four.
Old 12-25-07, 07:52 AM
SAFNYC
SAFNYC's Avatar
The link you sent shows two wheels, 18 x 8.0 and 18 x 8.5. I need a pair of each, right?
Thanks
SAF
Old 12-25-07, 10:30 AM
Fedor
Fedor's Avatar
Thanks
SAF
For the AWD, you would want four of the 18 x 8.0.
Old 12-25-07, 11:55 AM
CAIFAN_64
CAIFAN_64's Avatar
yeah for the AWD you need the 18X8.0 all around, also dont forget this wheels are in a group buy for 796dls for the whole set until the end of the month
https://www.clublexus.com/forums/sho...d.php?t=311960
Old 12-25-07, 04:57 PM
lexus 951
lexus 951's Avatar
can i my stock tires fit these rims ?
Old 12-25-07, 05:47 PM
CAIFAN_64
CAIFAN_64's Avatar
yes they are exactly the same size as the oem rims. but if you have the awd you cant use them because the tires are size 17"
Old 12-25-07, 05:54 PM
solo_stage
solo_stage's Avatar
you need four of the same wheels in order for the dealer to say it will "fit".... and of course the dealer is not going to buy half of two sets of wheels so if u want them u can buy them urself
Old 12-25-07, 05:55 PM
solo_stage
solo_stage's Avatar
with my understanding... AWDs usually only come with 17s...
Old 12-25-07, 08:18 PM
SAFNYC
SAFNYC's Avatar
Wait a sec. One guy says I need 18x8.0 in the front and 18x8.5 in the back, and now you're saying I need 18x8.0 all around. What do I need for the IS AWD?
Thanks
SAF
Old 12-25-07, 10:36 PM
solo_stage
solo_stage's Avatar
18x8.0 ALL AROUND.
Old 12-25-07, 10:37 PM
solo_stage
solo_stage's Avatar
its an awd... awd means ALL WHEEL DRIVE.. meaning same wheels all aroudn
Quick Reply: Dealer says G-Spider alloy wheels don't fit on IS 250 AWD
