How To Turn Off Annoying Beeping Of Open Door!!!
So today I decided to hardwire my new V1 I got for x-mas. I then had the door open when installing and the car would not stop beeping. I pushed the little sensor in the door seem in, and then released it, and to my amazement the beeping stopped. This was very helpful for me and I will definitely use it in the future. I will take a picture tomm when I walk downstairs to show what sensor i'm talking about, although it is a little rubber round piece on the frame near the seat. Sorry if this has already been discovered but i searched and didn't find anything!
Back to the OP, that's the door "courtesy switch." It turns on power to things like the courtesy lights, doorsills, etc., and the ECU uses it to determine if a door is open. So yes, pushing in this switch will fool it into thinking the door is closed.
I'm surprised that the '07 does this since the gerneral consensus in '06 was that this was a software bug. As someone said earlier, the beeping only occurs if the door is opened before the ignition switch is turned off, and won't quit beepiong until the door switch is toggled. If you turn the engine off before openeing the door, it won't beep at all. It would seem that the correct behavior would be for the door chime to sound only until the engine is cut off if the door is opened early.
I agree my car does the same, chimes with a mind of its own! Can we make a warranty claim, or is this just like the complaint I had about the RPM dropping suddenly when holding a gear, speed and RPM of 2-3 k? Either way kind of a pain for a Lexus.
is there any permenant fix for this awful chime, like the fix for the seat belt chime
i have the same issue...my car has a driver's side door open chime. it is extremely annoying and beeps whether i open the door with the ignition on or off. it only stops when the door is closed...and if i reopen it...no chime but i guess this is basically the same thing as pushing in the sensor and releasing it. regardless, the chime is inescapably annoying and embarassing whenever passengers and/or passer-bys are near.
the beeping seems to be a safety system tied in with the electronic steering wheel lock. if you turn off the engine and then open the door, the wheel locks, and no beeping. if you open the door then turn off the engine, the car beeps until someone either closes the door or opens any other door on the car and locks the wheel.
