Will child seat fit in back of IS?
#31
I have a 10month old. Currently still using a rear facing in the center using the latches. (the distance when using the "latch system" using the loops closest to the center is only 2.5" further apart than using the latch in an outside seat outside (11.5" vs 14").
For me, and as little as she is back there, it is fine, however if I had her regularly in my car, As in more than 2-3 times a month, I would buy something else. It is very tight back there, even in the trunk especially once you start throwing strollers, and diaper bags, etc.
If I was looking today, I'd be looking at the G35 and TL in this class, if I didn't skip it altogether for the next size up (GS350 which is tight also in the back seat, the M, the RL, etc.) or if I was allowed to drive a station wagon, a Volvo V70R (of course chipped and exhast'd- nothing screams sleeper like 400hp station wagon!) would be my ride!
#34
I haven't tried putting my seat in my IS350 yet since we also have an Infiniti FX35, but I'll have to do it sometime. When she hits 6 months I'm planning to get a Britax Diplomat (new), which is designed for smaller cars.
#36
#38
I don't know if this varys by state, but I just took a child safety class a couple weeks ago here in Texas (daughter born yesterday), and it was clearly expressed that children are legally required to be in a rear facing seat until at least 1 year AND at least 20 lbs. Both conditions must be met before the seat can be forward facing.
http://www.iihs.org/laws/ChildRestraint.aspx
#39
#40
1. The LATCH system is not intended for center seat installs unless a third set of anchors is installed. Using the two outer-most anchors must accompany the shoulder belt installation because the distance between the anchors is nonstandard.
2. The LATCH anchors are connected to the frame, and bending of same in a bad accident could result in a middle-installed seat being torn apart.
It's an individual choicel. I heard enough input from other parents to keep me from installing in the center of the seat, although I understand the rationale.
#41
The latch systems in our cars were not designed to be used in the center, only on the two sides. If the latches are more than 11" or something like that, it's not suppose to be used. Usually you can find the dimensions in the manual. If you use the center seat, you should use the lap belt to secure the seat. If properly installed the base of the seat should not move more than 1/4 or something like that. In the pic I posted earlier, I used the towel to level out base of my convertible seat so my kid wouldn't propped at high angle. The snugride bases have the piece you can adjust so you wouldn't need a towel.
#42
#44
I wne t to babies r us and checked out the britax diplomat and is probably the best fit, it certainly is smaller than the rest i have see, i will be picking one up, in black when they get it in. they only had beige @ the time, anyways thats my 2 cents!
