SSR Vienna Zweel
I just want to find your opinion on SSR wheels. Are they the same high quality as Work? I'm interested in the Vienna Zweel in 19x8.0F and 19x9.5R. What offset and tire sizes should I run with these? I'm currently lowered on Eibach Pro-kit. Your suggestions and thoughts are much appreciated.
Loves Snickerdoodles!
You might want to PM fellow CL member GSXOTIC. He has these wheels on his LS460, maybe you can ask him for his impressions on the wheel.
Here's a pic
Here's a pic
nice wheels. i think +36 is the best offset. and 225/35/19 or 235/35/19 for the fronts depending on tire brand and offset. 265/30/19 for the rears i believe.
Thanks guys for your help.
Jsquared, I was thinking of running 19x8.0F with Goodyear F1 GSD3 225/19/35 and 19x9.5R 265/19/30 to avoid rubbing. So, would +36 offset be the best fit for this set-up? Is our cars considered "normal disk"? I'm not intending to upgrade to BBKs or Brembos. If that is the case, would I be able to run +37 as listed in the chart?
One of the good things about these rims is that they're also TPMS compatible. Thanks, Cspec. I didn't know that these wheels are forged.
i think what you chose should be fine. the 350 front calipers kinda make it more complicated but since u don't have that problem you should be ok. post pics when u get them on!
