Another Tpms Solution.
#52
Just to let you guys know, this solution works perfectly. Mad props to the OP who thought of this. You just have to make sure the zip ties are tight. Covering the warning lights is ok, but then it's annoying when the HUD keeps reverting to the "Check System" text when you want to be looking at the temperature or MPG, or in my case, a nice "F" logo.
As for blow outs... yes it's nice to have a warning, but by the time the system tells you that something's wrong, you should already notice that the car is not driving straight and pulling. If you are unaware of the way the car drives, then no system can help you.
#53
In the past two months, I've had three separate nails in my rear tires. Looking at the tires, I would have never known they were low on air - they looked exactly the same as they do when fully inflated. The ONLY REASON I knew they were low on air was the TPMS warning I got on the dashboard, which saved me from driving on and most certainly ruining my wheels. Please please please run your TPMS - you paid for them, and with iForged selling the set of TPMS adapters for as cheap as $35, there's really no reason not to.
Javier
Javier
#54
Trust me; you may not have the time. It can happen without any visual clue or warning-- no pulling or handling changes. In fact, that’s the whole reason a federal law was passed to require TPMS. Remember the SUV’s with Firestones a few years ago that caused a multiple fatal rollovers? This is the new safety requirement that some of us foolishly bypass.
#55
I dunno about you but Ive owned enough cars to know you dont need tpms. If there is a nail in your tire you should be able to hear it or you should be able to feel the car to be a bit mushy. If its a serious leak/blowout Tpms wouldnt help anyways. Its a luxury that does have its benefits. But definitely not needed.
#56
As for owning enough cars, I probably have owned more than you. I started driving in the fifties. Back then we didn’t have air bags, seat belts, padded dashes, collapsible steering columns, dual brake lines, anti-lock brakes, third brake lights, and of course TPMS. I survived all those deficiencies. Does that mean they were not needed? No, it only means I was lucky, and the decrease in accident and fatal injury rates in recent years proves that.
I still don’t understand how some of us choose to roll some dice for the sole purpose of having aftermarket rims that do not support TPMS when there is a multitude of rims to select from that do.
#57
Even if you want to run non-TPMS compatible wheels, it's more an issue of being lazy or cheap. With the resources available on the market, this is far too easy an issue to solve especially when considering the consequences.
Javier
Javier
#59
There are certainly enough CL members rolling on SC1's - can any of you chime in on your TPMS solutions with this particular wheel?
Thanks (and yeah, those pics on page one would be great)
