Weatherstrip falling apart at rear window
Or maybe I will try to fix it myself this weekend by "pulling it" as mentioned by KiKaika....
You also mentioned pulling off the upper strip and remount it back, did you mean rip the whole thing off and push it back without taking apart the trim at all?
Thanks a lot!
Well, very soon you will find that the otherside starts falling apart too, but not as bad. No kidding.
I looked at a few IS's on the street and noticed some of them have the same problem. It could be my imagination, but I think it is always worse on the passenger side....
I hope it does not develop leaks over time. That's my other concern. I guess if it has been okay for you for four years, then maybe it won't leak....
Anyway, I would say I roll down my window average about 5 times a week last year which I think is normal use. It is happening to the other side too but about half as bad. I do use the window on the driver's side less frequently.
Please don't tell me I cannot open my windows!!
I've had 3 IS's and all have had the issue. It's not going to leak at all but it's a very easy fix. All that's happening that window it pushing up on the weatherstripping when it's ****. If you open you window all the way you can pull down the complete weather stripping in the area and pull it down, stretch it back into place and snap it back in. It's simple and i've done it a couple times now.
