info i found....
Found this on another site while doing a search, just wanted to pass it along....maybe we can keep this stored somewhere???
Here is some info on the New IS350. Just thought I would pass along..
Audio:
12V+ is green at Radio Harness
Acc is Orange at Radio Harness
Ground is White/Black at Radio Harness
Illumination is Green(+) at Radio Harness
Power antenna is Yellow(+) at radio harness
LF speaker (+)Light Blue
LF speaker (-) Orange
RF (+) Black
RF (-)Gray
LR (+)Light Green
LR (-)Blue
RR (+) Light Blue
RR (-) Red
Misc items:
-Headlights low beam is Red/White(-) at pass fuse panel gray 10 pin plug.
-Hazards is Lightblue(-) at switch or Yellow(-) at pass BECU(24 pin plug)
- Wipers low is Yellow(+) at driver BECU 26 pin plug
- Wipers high is Reb/Blue(+) at driver BECU 26 pin plug
- Parking Brake is Yellow/Black(-) at switch
- Trunk release is Pink(-) at switch or Passenger BECU 28 pin plug
-Fuel door release is Blue(+) at switch
-Seat memory 1 is Lightgreen(-) at switch in door
-Seat memory 2 is Red(-) at switch in door
-Horn is White(-) at steering column
-Reverse lights are Yellow(+) at driver fuse in 30 pin gray plug
-Brake lights are Red/Black(+) at brake switch
-Low current parking lights are Yellow(-) driver fuse 28 pin plug
-Speed sense is Blue(AC) at amp is passenger side of trunk
-Tach is White(AC) at data link connector
-Power lock is Blue(-) at switch in door
-Power unlock is White(-) at switch in door
(An extended pulse will roll windows up or down! A module is available already to interface this!)
Please note that Power source controller(PSC) is located behind the Glove box!!
Battery is Orange(+) at PSC 40 pin plug
Ignition 1 is Light Green(+) at PSC 40 pin plug
Ignition 2 is Pink(+) ate PSC in 40 pin plug
Acc1 is Light green(+) at PSC is a 40 pin plug
Starter1 is Light Blue(+) at PSC 40 pin plug
Starter 2 is Violet(+) at PSC 40 pin plug
All door trigger is Violet or Pink(-) at driver BECU 10 pin plug
Trunk trigger is Blue or Green(-) at Pass BECU 28 pin plug
Hood trigger is White/Blue(-) at switch must diode isolate
Alarm arm is done with door locks
Alarm disarm is done with door locks or Ignition and transponder!
Audio:
RF (+) Black
RF (-)Gray
LR (+)Light Green
LR (-)Blue
RR (+) Light Blue
RR (-) Red
Misc items:
dusouth
66
11-02-16 11:35 AM
skybluecrx
07-27-08 08:03 PM
LovEnPeaCe
04-28-07 10:04 PM
