How can I make an MP3 CD and remove the 2 sec gap?
I tried searching but can't find how to remove the 2 second gap in between tracks. I made audio mp3's from a live DVD concert using audio extractor software and I am trying to take those mp3's and make an audio CDR and I DONT want the 2 sec gap.
First I tried iTunes:
If I use the option make audio CD I can remove the 2 second gap between songs BUT I can't fit the entire live concert on 1 CD instead wants to make multiple CDs.
If I use option make MP3 Disc, itunes still keeps the 2 sec gap, I tried making all the songs from a gapless album but it still burns it with a 2 secd gap in between songs. How do I remove the 2 sec gap using the mp3 option w/ itunes?
Then I tried Nero
This will work and remove the 2 sec gap but I can't get the songs in the correct order, Nero wants to sort the songs by Title NOT by Track, I need Nero to sort the songs from the concert by track order so there in the correct order. Nero also won't let you drag and drop WHERE YOU want to, everytime I drag and drop each song individually it keeps sorting the songs by title or album or location but not by track order.
Any one can help? Thanks
Then I tried Nero
ok, just googled it, seems alot of people can't do this either, seems the only solution is to make 1 mp3 file instead of separate mp3 files to avoid the gaps if you want to make an mp3 CDR otherwise just stick w/ making an audio CDR to avoid gaps but if your music is over 80 min you will have multiple CDR's.
My whole point was my concert is over 80 mins and I wanted 1 disc so I thought I could mp3's into separate tracks w/ tags but you can't do that without gaps in between.
