Smart Key Fob Programming
Old 01-21-08, 08:26 AM
FrankyJ
FrankyJ's Avatar
Location: Sleep in Long Island, Dominican Parties in Queens
Default Smart Key Fob Programming
Does anyone know the instructions to Program our Key Fobs. I ordered one from Sewell and I thought instructions would be delivered as well, but I was wrong, and the site says
you may attempt to program your Lexus key yourself with the proper key programming instructions.
so any help ill appreciate
Old 01-21-08, 08:31 AM
t.is350.h
t.is350.h's Avatar
You have to bring it to the dealer to program it. You can't do it by yourself. The dealer will charge about $55 for programming the key fob.
Old 01-21-08, 08:53 AM
Bichon
Super Moderator
Bichon's Avatar
The key doesn't get programmed, the car does. The process requires a factory scan tool, so as t.is350.h suggested, your best bet is probably a trip to the dealer.
Old 01-21-08, 09:20 AM
chums
chums's Avatar
realistically, labor's only about 10-15 minutes to reprogram a key. my dealership does not charge people to get keys programmed unless it involves resetting the ecu or more. you plug in the comp, follow the directions, wait a bit and then its done.
good thing about smart keys is the remote gets programmed automatically as well. with other keys, such as keys for the rx, it involves a complex process of opening/shutting/locking/unlocking doors and pulling the key in and out of the ignition several times.
Old 01-21-08, 10:16 AM
FrankyJ
FrankyJ's Avatar
ok thanks guys... 10-15 minutes... so shouldnt be more than 30 bucks if they decide to charge right?
Old 01-21-08, 10:26 AM
Akatsuki
Akatsuki's Avatar
nope they going to charge you full price ... mine was 45
Old 01-21-08, 10:36 AM
t.is350.h
t.is350.h's Avatar
where did you program it? that's cheaper than where I have the key to programmed.
Old 01-21-08, 11:25 AM
akkord
akkord's Avatar
I got mine done for $50 at Newport Lexus when I got my brake TSIB done...
Old 01-21-08, 11:32 AM
Akatsuki
Akatsuki's Avatar
lexus dealership .. i called toyota they were charging 88 bucks im like wtf...
Old 01-21-08, 05:20 PM
FrankyJ
FrankyJ's Avatar
i called the place i USED to take my car for service to, and when asked for the price i was answered... Ionno its 108/ hr and however long the tech takes. Great answer...
So then I called the place i currently take my car for service and was given a straight up answer... 49 bucks... gosh im happy i changed
Old 05-08-08, 09:41 PM
joehsy
joehsy's Avatar
Default program another car with the same key?
Hi I have a Camry Hybrid as well and if it is true that the smart key fob isn't programed, but the car is, then theoretically it should be possible to have the camry programmed to the same key? They both have the same spec:
FCC ID: HYQ14AAB
IC: 1551A-14AAB
DENSO
Or is there something on the key fob itself that limits this?
//Joe
Old 05-11-08, 04:50 PM
lexusscguy
lexusscguy's Avatar
FCC ID: HYQ14AAB
IC: 1551A-14AAB
DENSO
//Joe
We have an Avalon and the key fob has the same numbers also, I called both Toyota and Lexus and asked that exact question, if one key fob can be programmed for both cars, and they both told that it could screw up the system. If anyone knows more about this, please chime in.
Old 05-11-08, 05:26 PM
Bichon
Super Moderator
Bichon's Avatar
Just an educated guess here, but I think it has to do with the rolling codes. Each time the transmitter in the fob broadcasts, either because the button was pushed or in response to an interrogation by the reader in the car, it transmits the next code in the sequence. Since it is possible that you might push a button while outside of the range of the car, the car will not only accept the number it is expecting, but any of the following (usually 256) numbers in the sequence. If both your cars were using the same fob, but you used it with just one car for a period of time, the code would roll far enough forward that the other car would no longer recognize it.
Old 02-02-10, 05:02 PM
vdeleon
vdeleon's Avatar
I know this is an old thread but I'm a new proud owner and just got my spare key for my 99 LS400 and came with programming instructions....followed it...done!
Old 07-21-10, 04:46 PM
jmstevens
jmstevens's Avatar
So can you post the steps?
Quick Reply: Smart Key Fob Programming
