Cold air in my face. Is this acceptable?
Driving to Chicago from Central Illinois the other night. Outside temp was -1 F. Car temp set on AUTO and 73 F. Car speed around 75 mph. My wife remarks that she feels a faint "cool draft" on her face. I also had noticed it but didn't make much of it--thought it was a nifty Lexus trick to keep the driver "alert" when the cabin temp warms above a certain setting.
I turned display to CLIMATE and see that fan speed is medium-low and vents are directing air to footwells. Placed my hands over the panel and dash vents. There's a small amount of warm air from them as well. Traced my hand along the A-pillar/front windshield junction and the driver's window frame--I actually felt some freezing air on my fingertips! Obviously, I checked to make sure all windows were up all the way (they were). I didn't appreciate any significant wind noise at the time. I set the airflow to the dash/footwell mode and that helped quite a bit, but feeling the cold air penetrating the cabin was disconcerting.
I don't recall this in other cars I've driven (except my convertible ), but then again I don't remember the last time spent a couple hours at interstate speeds in subzero temperatures.
Has any other cold weather owner experienced something like this? Is this considered "within tolerance" for Lexus? Is there a way the seals in those areas can be augmented without ripping out existing seals, windshield, etc?
Thanks.
Thanks.
Again, I'm not sure if this is considered "normal" (since no car is air tight) and I just hadn't noticed it in other cars I've driven. Not to mention that I can't recall ever driving in temps that cold...
I could see that if the cold air was coming from the vents or the dash, but it wasn't. It was coming from the windshield and front window frame edges.
If you selected outside air, there will be a certain percentage of outside air regardless of what the temp is set at. As soon as the interior reaches the set temp, the system will slow the fan speed and use more outside air to maintain the set temp. Also more outside will be used if the system senses humidity. If you select recycled interior air you should not feel a draft but the windows my fog.
Koz
Koz
come on! everyone in IL drives with the moonroof open doesnt matter the temp!! i will tilt it up at times even when its cold to have more fresh air in the car. i cant stand when its really hot from the heater and all stuffy.
if you do recirculate the air you will take care of the "fresh" cold air you are feeling coming into the car. this is problem more noticable in IL with the colder temps right now. yes its better IMO to have the fresh air for several reasons and the one most important to me is the air getting dry from the heat. But my wife has mentioned she feels it more in this car then any other on how it almost feels like its blowing on you.
