HELP! ASAP Please!!! Dealer claiming BS about Fujita Intake...
#32
If an SRI is causing a lean condition, then something would have to be allowing air to bypass the MAF sensor. A loose or even removed air filter will NOT do this. What could do this would be a loose MAF sensor, disconnected breather hose (between the MAF and throttle body), or a loose fitting between the throttle body and intake pipe. If your dealer is saying that only the filter was loose, then they are feeding you a line of crap.
I suspect that either you or your service writer is just doing a poor job describing the real problem, and it is just a loose intake pipe. If that's the case, then $95 is a fair price.
#34
Ended up paying the $95 and not saying a word. Thanks for the eye-opening words everyone. I guess I was just steamed and didn't want to see the reality of things.
Thanks!
Thanks!
#35
Philsogood
02-23-16 10:05 AM
