So my smart card came in today and I programmed it to the car.
Old 01-29-08, 08:46 PM
  #31
carchitect
carchitect's Avatar
The card key finally came in and here are the pics.
As you can see the battery is a CR2412 (3V) battery
Old 01-29-08, 08:52 PM
  #32
IS250HuNnY
IS250HuNnY's Avatar
good pics!!
wow that is so cool i want one
Old 01-29-08, 10:50 PM
  #33
MoLexus
MoLexus's Avatar
Looks sleek!
Old 02-10-08, 10:51 AM
  #34
carchitect
carchitect's Avatar
Here's an apdate.
The 08 keys are cut only on the inside and not on the outside. The 07 and older cars are cut on both sides. I had a CL member PM me about his dealer being unable to cut him the key or much less even understand how his smart card was working on his vehicle.
The 2000 and older lexes cars use a 4 digit code. The 01-07 cars use a five digit code that begins with 4xxxx and the 08+ use a 5 digit code that begins with 8xxxx.
Since the smart card key is one sided, it isn't available for the 07 and older models even if the smart card is programmable to the vehicle. I'm sure I could order an uncut key and make a spacer to position the key to get it cut in our key machine but it would take some trial and error. I'm unsure if the one sided key would unlock the door to a 2 sided lock. We might have to find out.
-Joe
Old 03-08-08, 06:27 PM
  #35
istundra
istundra's Avatar
Do you know the difference between the 07 LS Wallet Key compared to the 08 Wallet Key?
I know that the 07 Wallet Key Part # ends in ...40, and the 08 Wallet Key Part # ends in ...41.
Any idea?
Old 03-08-08, 11:11 PM
  #36
carchitect
carchitect's Avatar
89904-50641 is the new p/n#
Old 03-09-08, 04:30 AM
  #37
istundra
istundra's Avatar
I see. So these are pretty much identical part?..
Is the frequency the same? FCC ID #?
How about the key blade?
I have a 07 and I plan to get the wallet key blade cut to my car.
Maybe a locksmith can?
I'm curious if it needs the teeth on both sides to open. I can certainly deal with one side only then none at all.
Old 03-09-08, 09:02 AM
  #38
V.I.P.
V.I.P.'s Avatar
this is sick...next mod on the list
Old 03-09-08, 11:27 AM
  #39
carchitect
carchitect's Avatar
The code is a rolling code so the frequency changes. If the battery goes out the key can be placed on the start button and started via immobilizer chip.
I did find out that the 2-sided locks used in the 06-07 won't work if you cut a 1-sided key and try to use it. You would more than likely have to get a whole new lock set from an 08 model and have a key cut specifically for the new set. You could get an aluminum key cut and drill a 1/8" hole on the head and place it with your keys. But you won't be able to get a key to fit the wallet smart card.
Old 03-09-08, 01:25 PM
  #40
istundra
istundra's Avatar
I see. So both the OLD part #, ending in 40, and the NEW part #, ending in 41, will both work the same and be programmed from 06+ vehicles?
How about the trunk? Will a single sided key blade open the trunk? I may as well stash a double sided key blade in the trunk and use a single sided key blade to get to it.
Old 03-09-08, 01:33 PM
  #41
pocky
mooncake master
pocky's Avatar
If a one sided key blade won't work on the regular door cylinder, then why would it work on the trunk key cylinder?
Old 03-09-08, 01:38 PM
  #42
is250rida
is250rida's Avatar
how do u lock the doors other than the button on the handle? i don't see any buttons on the LS card
Old 03-09-08, 01:53 PM
  #43
pocky
mooncake master
pocky's Avatar
The button on the handle. That's it. There is no buttons on the Card key
Old 03-09-08, 01:59 PM
  #44
istundra
istundra's Avatar
I agree.. but doesn't hurt to try. Don't you want to know so you can have some options open?
Old 03-09-08, 02:02 PM
  #45
istundra
istundra's Avatar
dam. not having a backup key is scary. i might as well change my battery every 6 months... to make sure it is charged.
Quick Reply: So my smart card came in today and I programmed it to the car.
