NEEED HELP!!!!! messed up while trying to reset ecu
ok so i just went outside to reset my ecu.. since i took off my K&N.. and havent sinc ei got my full exhaust..
i pulled out the 25A fuse then when i pulled out the 10A fuse it popped off and went down into the engine.. i cannot find it!!!!!!!!
will my car operate.. or what
do i just goto a auto place and get another one
what do i do??
what do i do??
i ended up just having a buddy drive me to buy another one.. thanks though guys..
i just was worried about it b/c it says to remove the fuse for 1 min the put it back in.. so i wasnt sure if it would be bad to have it out for a few hours.. but i guess it wasnt.. b/c everything is working good now
First off ... quit resetting your ECU! It only takes a few miles of driving for the ECU to retune itself to a new intake or exhaust. The only reason why you should reset the ECU is if you are trying to clear a diagnostic code.
This is eactly true, and you need not remove fuses as well, only if they are blown. If they are blowing, then you have an issue. Don't wire anything into the fuse box either, you will be asking for trouble.
that was the first time i have EVER done it..
It isn't harmful to reset the ECU, just not beneficial. The car will take some period of time to "learn" how to idle smoothly, and may stall once or twice during the 1st few driving cycles. It may also get worse fuel economy while the long term fuel trims are recalculated. It also takes some time after a reset to be able to pass inspection since OBDII readiness codes take a certain number of driving cycles.
While this certainly may be the easiest way to do it, it's not always the right way. Disconnecting the battery also loses all your preset radio stations and any personal data stored in the NAV, such as waypoints, favorites, routes, and history.
