Custom eyelids...........What do you think?
na... but i am curious to know how you did it... they don't look right but not because of style... they don't look right because it looks bulky... if you could shave it down some... i think it would look better... contructive criticism... i can't wait to see some changes to it.
for an example if you look in this pic... definitely needs some touching up around the edges and around the area right above the side amber light where it starts curving down... overall the thinner the better...by the way your bumper is loose
you did good though if you made it out of fiberglass yourself.
keep in mind all aftermarket fiberglass eyelids are usually less than 1mm thick without paint.
I will try that thanks and should i use bondo on top of the fiberglass before painting or can the fiberglass be painted and look like the rest of the body?
My bumper is loose yes because i have 245 35 R20 on the front and i had to take out the screw so it stops eating away my tire untill i get new ones.
