Painted front grill
I did mine my self what i did was i sanded it down with 600 grit then put primer (4 coats), then primer sealer (3 coats), then paint (5 coats,I used import paint that i got from a local performance store which has served me well in the past) then after that i waited about a hour and then cleared it (7 coats).
(In between primer coats i wet sanded with 2000 grit)
After you put the clear on wait 48 hours then use polishing compound to remove any orange peel (there shouldnt be much if you did it right)
Total cost about $30....
what kinda rims are those?
Its not really that bad takes some time but most of it is waiting for the previous coat to dry. In all its about 3 hours but its only takes 20 min in reality if you dont count drying time.
im going to buy everything right now, think they will have it at walmart?
Im going to do this tomorrow when i paint my calipers. When i sand it down, how do i know when to stop? will the chrome sand off?
They might but make sure you use a paint that is (Acrylic Lacquer). NOT (Acrylic Enamel). Use the same brand of paints so that they are compatible I used Dupli-Color, there are diffrenet grades of paint I used the Higher one because it last longer and doesnt chip as easy it cost $2 more a can.
When you sand it with 600 grit do it lightly so you dont make lines that you can feel, just sand a little so the primer has something to stick to. The chrome doesnt come off, it almost looks like the whole grille is made out of it. But make sure you use primer sealer and wet sand with 2000 grit thats what makes the paint smooth. But make sure you wait 10 between coats before sanding, then rinse with water to remove the dust.
i bought the dupli-color and primer, i didnt see what kind of paint it was but if it is wrong ill go exchange it. Also on the back it says to use #200 sandpaper. The primer i got was sandable. i still have to go buy the Clear coat because i couldnt find it. Is it called Acrylic something..
