How can you check that the headlight turns?
Hello CL,
I am just curious to know how can you find out if the headlight actually turns. It's pretty difficult to tell when i'm actually driving. I know I have the HID and everytime I turn it on it does adjust up or down but i've never really noticed it turning in the direction I am turning.
On a stop or while parked, can I just turn the wheels and the lights should turn as well? Or does the car have to be in motion for it to move?
Thanks CL!
Thanks CL!
The "Adaptive" or AFS lighting is not available on the IS, I think just the RX and LS if I am not mistaken. The IS has the auto-leveler feature which adjust in order ot not blind uncoming traffic.
You are mistaken. The IS with stock HIDs does have AFS. I forgot to mention in my earlier post that the feature can be disabled via the same controls used for the TPMS (switches left of steering wheel); the original poster should make sure that his isn't turned off.
Looks like the AFS is still a seperate option on top of the HID's based on the chart. That would be a great buy for that roughly $800 option. Factory HID's are always better for many reasons. First and foremost, the auto-leveler and in this case, the AFS. Secondly, the sheilding of the ballast that does not interfere with the radio recption while illuminated and last but not least, the reduction of a potential moisture leak. I stand corrected if the AFS is standard with the HID package for the IS. I wish I was able to get the HID's OEM. None were on the lot without Navi.
If your car has the AFS you will notice it while your driving... I miss mine when I put springs on my car the AFS light turned on and they haven't been working since...
Though I am a fan of curiosity for curiosity's sake, I wouldn't recommend turning your steering wheel stop-to-stop when the car isn't moving, and definitely don't make a habit of it.
as what i know they have a sensor in the car and it only moves when you drive.....try make a left turn and you will see it moves.......btw, the left one moves more than the right one......
I'll check that out the next chance I get. It should be in the <o> control when the car is "on" position right?
