How much air pressure are you guys running in your 18s?
02-15-08, 08:59 AM
Tire Rack Rep recommends 42 lbs in a Goodyear F1.
Seems very high,doesn't it?
02-15-08, 09:19 AM
I run what it the engineers wrote on the sticker on the door pillar
02-15-08, 09:22 AM
Super Moderator
Same here, 35/37, on both the OEM Dunlops and on my Pirelli SnowSports.
02-15-08, 09:23 AM
Quote:
Originally Posted by
IS35O
I'm coming from 17" wheels and the door says
35 front
37 rear
Same numbers with the 18" factory rims?
02-15-08, 09:26 AM
Super Moderator
Joeb427
35 front
37 rear
Yep, same for the 18" factory rims.
02-15-08, 09:32 AM
Bichon
Ok thanks,those are the numbers I will use.
I would think 42lbs would cause a real rough ride.
02-15-08, 11:16 AM
I use "..." ....... a lot
The manual states that you can go up +7 psi if you do driving over 100 mph.
I keep mine at like 36 f/ 39 r. That way, it helps get a little longer treadwear without causing a rough ride.
But, has anyone noticed that the manual shows a different # than the tire tag on the door.???
02-15-08, 12:12 PM
For your 225/40/18 you want to run 35lbs
(on all for corners of your awd)
Joe Z
02-15-08, 12:26 PM
2IS/2RX/4RX
02-15-08, 12:33 PM
Joe Z
Joe Z
Sounds good to me.
02-15-08, 01:19 PM
Your ideal pressure is just that....yours . It all depends on how you want your car to ride/handle and on the outside temperatures.
The best pressure also depends on the specific tires themselves. I am currently running 36/38 at about 50 degrees on bridgestone touring tires (soon to be gone, hopefully).
02-15-08, 03:08 PM
i'm getting more than 40k on my stock tires with 3 psi more over the car's recommand.
02-15-08, 03:34 PM
2IS/2RX/4RX
shaolin: for both of you 250/350?
02-15-08, 07:29 PM
more then 40k on stock tires? crazy.. mine lasted to 15k.. lol a bit of a spirited driver i am
02-15-08, 09:00 PM
Using manufacturer's recommendations 35f/37r. Could go higher but I'm already riding on Eibach ProKit. Higher PSI = stiffer ride.
Geols430
06-03-16 12:21 AM
gebo
03-12-15 06:37 AM
doodlebug
12-08-13 05:51 PM
mrshabo
Wheels, Tires & Brakes Forum
16
04-24-04 09:52 PM
ChuH
06-20-01 01:39 PM
