aux volume independent?
I just noticed that the volume level on AUX is independent from Radio or CD. In other words, whatever level i set in AUX stays the same even if i change the volume in Radio or CD. Is this normal?
btw, the level for Radio and CD always matches.
Yes, I noticed that too recently since I have to jack the volume up to over 50 to hear my mp3 player but then when I switch it to radio it automatically goes down to what it was when I was listening to the radio.
Make sure to get the TSIB for the In-Line noisefilter installed in order to reduce that small whinning sound upon acceleration and an extrenal device hooked up via the 12V jack.
TSIB AU001-07
TSIB AU001-07
Not on mine. My Radio and CD volume are the same and i dont use SAT. I tested it earlier. Can someone else confirm?
Aux is garbage IMo. I did the tsib but no difference. when I use it the sound is not equally projected throughout the cabin, sounds like its mostly comming from the driver side. I'm going to get it checked out again when I go back for oil change. I don even use it since it sucks, maybe I have a defective unit
