Help: Rear Hotchkis Swaybars won't fit
as you can see in these links (https://www.clublexus.com/forums/sho...1&postcount=15 & https://www.clublexus.com/forums/sho...9&postcount=17) i am facing difficulties at installing the rear Hotchkis swaybars. The logical reasons that i can think of are:
a) wrong part
b) non US IS might be different
The parts on the sway bar are 22030359 which match the attached installation guide so that's out of question.
![](https://www.clublexus.com/gallery/data/500/IMG_7435.jpg)
![](https://www.clublexus.com/gallery/data/500/IMG_7437.jpg)
I have checked some suspension system parts and i know they are identical to the is350. The only other possibility that i can think of is that i have a different spare tire compartment to the rest of you US lot... do you guys receive your spare tire flat or filled up with air? i was wondering that maybe i have a larger spare tire compartment than the US model
-Hamza
a) wrong part
-Hamza
here is a pic i found that should show they are the same. its not a close up but looks to me like we can confirm they are the same from your pic. scroll down thru the pics on the 1st page. i think it was the third one? this is a us spec car...
https://www.clublexus.com/forums/sho...ght=combfilter
thanks, yea from what i can see they are identical, i see the same bend in the OEM sway bar & similar clearance
But I just noticed that JUN-TW's rear sway bar (click here) has similar bends to the OEM and are different from the straight Hotchkis'.... i guess the Asian IS might be a bit different after all.
Hotchkis did not get back to me, I am quite sure that is just an issue with the non-US models and I don't know what to do :<
I guess i might be selling them after all... oh god, now i have to swap the front ones back
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Received 1,062 Likes
Ok... took these pics for you today, since I was underneath my car for a few hours with the full exhaust removed.... ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
These should help you greatly... looks like its the spare wheel compartment that is different on your car...
2008 IS350 Rear Sway bar and surrounding area (US Spec)
![](https://www.clublexus.com/gallery/data/3376/0315081051.jpg)
![](https://www.clublexus.com/gallery/data/3376/0315081053.jpg)
Joe Z
Joe Z
^+100 grand respect and a million thanx Joe ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The US model has different clearance for sure. There is plenty of room in there for the Hotchkis to "sway". I'll probably order the rear ones from JUN-TW.
