ALL TSIB info on 07 IS 350..MANY OF THEM!!
I'm planning to bring my car to dealer and fix them these TSIB:
- dashboard rattle
- moonroof squeak n rattle
- seat belt sometimes squeaks
- excesive brake dust (will complain about this during 20k mile service - got free replacement when it is really needed
What else do u think I should complain about?
- dashboard rattle
But what if I only heard the TSIB when my car has 20k miles on it? What can the dealer argue about that?
Tech Info Resource
You change your brake pads when they are at or below 1mm in thickness according to the service manual. If you can do that in 20k miles, you need to stop riding the brakes with your left foot. The pads have 11mm of useful life. I wore mine less than 2mm in 20k miles (with the original dusty pads) so I have no sympathy if you are killing your pads in 20k.
If you failed to complain about the dust from the brakes on your wheels, it doesn't matter when you found out about the TSIB, they're not going to change the pads for you.
There's a LOT of BS about TSIBs in this thread, and apparently a HUGE misunderstanding of what they are for. TSIBs address problems Lexus is finding complaints about. Those complaints are common enough and frequent enough to get their attention to authorize a common procedure under warranty to address the complaint. TSIBs are NOT recalls. They address specific complaints. Nothing more, nothing less. They also include things like predelivery inspection procedures, and other issues common across the Lexus line, so the NUMBER of TSIBs you see on a website is NOT indicative of quality issues or even common failures.
Having a dealer do a TSIB for an issue you have not experienced is just plain DUMB. If you are NOT experiencing a problem - if the dash doesn't squeak, if the engine doesn't make noise on start up, if the brake dust doesn't bother you - LEAVE YOUR CAR ALONE!!!
Super Moderator
Tech Info Resource
There's about 4mm of pad left when the slot is gone. Still not toast, and 27% of the useful life is being tossed in the trash.
Click here for more brake wear related info. Direct measurement, not speculation. Extrapolate as you please. Using the same driving style, I went through discs and pads on my Supra in 63k miles.
Coconut
Suspension and Brakes
12-07-07 02:07 PM
