Running 18x8.5 OEM wheels on all corners?
Old 03-04-08, 07:00 PM
Janizary
Janizary's Avatar
Default Running 18x8.5 OEM wheels on all corners?
I apologize if this have been asked. I did check the FAQ and didn't see the topic (though it could have been buried in one of the threads that was not specific to this topic).
I am curious if anyone is running 18X8.5 OEM wheels (standard, ISP, G-spider) on all four corners of their IS. I would like to be able to rotate my tires properly and am looking to buy a set of G-Spider's to replace my staggered 'standard' IS wheels. I was thinking of getting all 18x8.5s if that is doable. Otherwise, I'll just get all 18x8s.
Again, I apologize if this has been asked and answered before.
Old 03-04-08, 07:24 PM
sincityIS
sincityIS's Avatar
Yes it is doable. I had 19x8.5 and a 35mm offset and it worked great. The OEM wheels are a 45 offset so you will be plenty good. I actually have 2 rear wheels that I am selling that are in great condition if you are interested.
I live in Vegas to so we could meet up to do the transaction.
Old 03-04-08, 09:39 PM
is4fsr
is4fsr's Avatar
Putting the 8.5x18 in front will rub according to some ppl. In the past some members took their cars to the dealership for the free first oil change and the wheels were rotated and there were rubbing issues. Maybe putting spacers will do the trick if you're not lowered.
Old 03-04-08, 09:52 PM
eric_r_ho
eric_r_ho's Avatar
It'll rub just a bit with the inside fenderliner..but not enough to do anything detrimental to the car..
Old 03-04-08, 09:54 PM
VIS250P
VIS250P's Avatar
I beleive the wheels were rotated have different size tires.. That what make them rubbin...
Old 03-04-08, 11:15 PM
sincityIS
sincityIS's Avatar
They will rub if you keep the 255s up there, but most go to 245 and they are fine.
Old 03-04-08, 11:52 PM
EyeKutr
EyeKutr's Avatar
i have sold all 18x8.5 rears to a guy with an IS, no problem he told me, he did use 245 40 18 all around
Old 03-05-08, 12:30 AM
al503
al503's Avatar
The stock rears are actually +50, not +45.
I've got 8.5" +40 wheels in the front and I can just barely squeeze my pointer finger between the lip and the front spindle. It was so close that I was only comfortable going with 235/40 instead of 255/35's.
I tried putting the stock rears on the front and they won't even seat fully with the 255's on. I doubt 245's would do much better. Whoever is running that set up should pull the wheel and make sure he/she isn't rubbing on the spindle.
Old 03-05-08, 04:59 AM
passnu2
passnu2's Avatar
with the right size tire this will work just fine. if you use the same size tire that is already on the rear rims you will rub. still wont be able to rotate but can have a wider rim in the front if that is what you are looking for!
Old 03-05-08, 10:25 PM
is4fsr
is4fsr's Avatar
Ya. that's what I meant. Staggered set up and the rear tires put in front.
I think that will work - putting 235 all around or even 245s. OP wants the same size tires so he can rotate.
murfman89
08-22-17 08:49 PM
Ecohman
02-22-17 02:40 PM
bruce van
Wheels and Tires Classifieds
21
12-06-16 11:40 AM
ahmedp
07-23-14 03:04 PM
Individual
08-29-13 09:28 AM
Quick Reply: Running 18x8.5 OEM wheels on all corners?
