automatic tire calibrate???
aite so im in the search for new rims...and basically i will have different size tires...
does the IS have the capability to sense the new tire sizes when the new tires button is pressed...
i kno..noob question..lol
You can program a second set of tire sensors.. but in case you're asking a different question that I think you're asking-
AFAIK the car has no idea what -size- tires you have, so if they're not the same diameter as OEM your spedometer and odometer and all that will be wrong... Not sure if this is something the dealer can change with a Tech-2, but it can't be changed by the end user at any rate.
