Is This Pink Discharge (residue) In The Engine Normal?
That's coolant fluid from the radiator. May have a leak somewhere, but check the level and fill up if low. Just bring it to your dealer to have them check it out and see if it's major. Don't let them rip you off though, tell them to ask you before doing any work, but doesn't really seem major, could be wrong.
I don't have a problem with that. What year is your car, and how many miles?
Tech Info Resource
Yes. Mine has the exact same appearance. It is coolant. Clean it off with water if you don't like it. Taking it to the dealer is a total waste of time.
Tech Info Resource
Wow! that is heavy duty...over 100K miles until a change...That is just awesome!
Received 1,064 Likes
I also took it a step further and replaced my overflow hose with a new longer one, to the bottom of the radiator fan shroud..
The way it should have been from the factory..!!!
Now I have "no pink discharge" anywhere... If its going to overflow out of that hose (which it wont), it will end up on the oil filter service door/panel..
instead of a few drops making a mess in the engine area(s)
I'll take pics when i do my next oil change..
Joe Z
Dirtyd210
09-20-20 05:26 PM
Lookyoung
12-12-10 08:00 PM
