Replacement bulbs. DRL/High/Fog *Before & After PICS*
I purchased all MTEC bulbs to match the factory 4350K HIDs. Here are some before and after pictures. I don't understand why Lexus don't match the lights to start with.
Before (Yellow/Brown looking standard bulbs)![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![](http://i77.photobucket.com/albums/j79/mikewads/IMG_2299.jpg)
Parking light and Fog
![](http://i77.photobucket.com/albums/j79/mikewads/IMG_2297.jpg)
High Beam
After (matching 4350k white)![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
![](http://i77.photobucket.com/albums/j79/mikewads/IMG_2420.jpg)
![](http://i77.photobucket.com/albums/j79/mikewads/IMG_2423.jpg)
High Beam
![](http://i77.photobucket.com/albums/j79/mikewads/IMG_2424.jpg)
Closer shot of High Beam
High Beam
High Beam
I tried b4 reading some posts about DRL bulb replacement. I got silverstar to get a clear/white look for DRL only to find out after that a lower wattage is used for DRL so it still looks dim/yellowish. I want to try the smt 9005 leds. To get that bright white look for the DRL.... Think it work instead?
Don't care about High beams usage
The DRL is just a tiny little 194 bulb sitting in the same housing as the 9005 high beam bulb. The DRL stays on when the low beam HIDs are on.
1 x MTEC 2X Super White 9005 (MT-442) = $24.99
1 x MTEC Superwhite 194 (MT-223) = $8.99
https://www.automotivelightingusa.com/
OK guys, DRLs are high beams right.. I want to change the DRLs for LEDs but I did not know that DRLs do two jobs. Now, if I change the DRLs on my is350 what could use or do in order to use they as high beams too without doing a mess. Thanks you.
levinsoy
01-08-17 11:49 AM
BrandonIS
12-22-12 06:44 PM
