Paddle shifter beep
Old 03-17-08, 02:13 PM
dojoman
dojoman's Avatar
Default Paddle shifter beep
Does 2IS beeps when you're driving in "S" mode when trying to downshift to unsafe gear? IS-F does this, but someone else here mentioned it does for 2IS also. I've never heard that beep on my 350 and thought maybe it was turned off in LPS?
Old 03-17-08, 02:27 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I know the first gen IS does that....not sure about 2IS.....
Old 03-17-08, 02:36 PM
T4styPh0
T4styPh0's Avatar
Happened to me before. It doesn't downshift but instead it beeps until you've slowed down to a safe rpm then it will downshift.
Old 03-17-08, 02:54 PM
dojoman
dojoman's Avatar
So it does beep? Weird, I've never heard of that. Could it be in personalized setting? So what you're saying is that if you're driving on the freeway and you tried to downshift from 6th gear to like 4th and you will get beeps?
Old 03-17-08, 03:24 PM
T4styPh0
T4styPh0's Avatar
It depends on the speed and rpm you're at. For example, if I'm using the gear shift, I usually shift around 35mph which is pretty much near redline. Cruising on second at about 43mph then decide to drop into first again, it won't let me (beeps). Since 35mph is near redline, shifting from 43mph to 1st would just over rev the engine. Hope that helps, tried to explain the best I can.
Old 03-17-08, 03:38 PM
dojoman
dojoman's Avatar
Ok thanks. No wonder I never heard it cause I never wait until redline, man you do abuse the engine a lot.
Old 03-17-08, 03:57 PM
T4styPh0
T4styPh0's Avatar
Haha yea when I had the 250 it needed to be spanked for it to get up and go. But don't need to with the 350
Old 03-17-08, 08:48 PM
hihi410
hihi410's Avatar
Wow didn't know that either. I saw a video for IS-F but I didn't even think of it as a feature for IS 2gen.
I guess I dont' drive my car hard enough for it to let me hear the "Patience my friend, patience BEEP"
Old 03-27-21, 05:54 AM
Newme2
Newme2's Avatar
Default Lost my beep
how do I get the rev limiter and beep back I lost it somehow?????
Old 03-29-21, 04:12 PM
bakalag
bakalag's Avatar
My car doesn't beep for up shifts like the IS F, I wish it did. easy to bounce 1st gear... but if I try to downshift at say 5500-6000 rpm? it beeps at me saying "no stupid" lol
Old 03-29-21, 06:29 PM
Newme2
Newme2's Avatar
Default Lost
how do I get it back I think mine isn't working what could it be ?
Ltaboso
IS F (2008-2014)
12
05-26-15 09:44 PM
GiGAS
Performance
23
07-26-12 12:20 AM
dorkacho
01-18-12 11:34 AM
Rattltrunk
05-02-11 06:05 PM
pumper
01-27-06 03:14 AM
Quick Reply: Paddle shifter beep
